Oktober 23 2026 02:59:28
Tråd skapare: VolvoV50466
Tråd ID: 1589
Volvo V50 Power steering died - Solved
VolvoV50466
Hello everyone,
A month ago, I bought a great 2005 Volvo V50 with the 140hp 5-cylinder engine.
The timing belt replacement was due, which I took care of this past Tuesday. It was a massive job, but it all went well. If anyone needs tips on that, feel free to message me. After the repair, the car ran perfectly for a 20 km test drive. However, I did notice a high-pitched whining sound from the power steering when parking.
The next morning, I got a "Power Steering Service Required" error message on the dash, and the power steering had failed completely—I could only steer with a lot of effort. Interestingly, the whining noise was gone. I read the fault codes from the power steering pump's control unit, which I will attach.
I've already tried to see if anything was pinched or damaged during the timing belt job, but I couldn't find anything. There are no leaks, no bubbles in the reservoir, and no fluid loss. The only thing I can think of that might be related to the timing belt change is that my ambitious friend, who was helping me, spilled some coolant when refilling it without a funnel. The idiot. However, I checked the two connectors on the power steering pump; they face downwards, so it seems unlikely that coolant would have gotten in.
I've confirmed the fuses are okay (both the main MIDI fuse and the one in the cabin), and the alternator is working correctly.
At this point, the only possibility I can think of is that the power steering pump itself has simply died.
Can anyone help me solve this mystery? Has anyone had a similar problem?
Best regards to you all,
Noah
VolvoV50466 bifogade följande bild:bild:
Redigerat av Sladdaren den 22-09-2025 11:33
Do you hear the pump working when you start the car ? If you cant make it to work anymore and its broken you could try repair it. The video below i think shows how to.
VolvoV50466
Thanks very much for your reply - The pump doesn't make any noises anymore, it did as described in my initial post, after it died it did not make any noises, not when starting the car and not when turning the wheel.. I do wonder if something electronic inside the pump died hence the error codes I attached..if a bearing is shot like in the video, you would probably at least hear something..
I have ordered a replacement pump and will keep you posted once I have installed it.
Best wishes!
Noah
VolvoV50466
Hej,
Today I installed a used replacement pump and it wokrs again!
Hope for a long time Smile
God Natt!
Noah
VolvoV50466 skrev:
Hej,
God Natt!
Noah
Nice, tank you for the solution on this problem Tummen upp
· Besökare: 21
100,986,542 unika besök
