Oktober 22 2026 23:47:17
· Så här byter du va... 21669
· Lösning på Felkod ... 20710
Tråd skapare: Torbik
Tråd ID: 807
945 D24TIC crankcase -SOLVED
Torbik
Hello again! Sorry for not putting this in the English section.
Could anyone show with pictuses or with a diagramm, where ise the plug for the crankcase located for letting oil out when exchanging oil?
It is not on the bottom like in the gasoline models.
oktober 09 2016 12:25:45:
This is the bolt in the back of the crankcase i1307.photobucket.com/albums/s596/Nurmkana/20161009_103040_zpsanybdsju.jpg
could it be the bleed nut?
What bolt is this in front of the engine? i1307.photobucket.com/albums/s596/Nurmkana/20161009_103128_zpshpjij0hl.jpg
Also can anyone identify these parts, from a oil filter maybe? i1307.photobucket.com/albums/s596/Nurmkana/14642650_967864206700598_859537917_n_zpsf45pffmt.jpg[/URL]
Redigerat av Sladdaren den 11-10-2016 13:04
Sorry my english is sometime a bit rusty stupid. Are you going to change the oil in the engine ?
Torbik
Yes.
I will answer my own question: the spring and the other part are from the oil pump. and the bolt in the front of the engine is also from the oil pump. http://www.volvopartswebstore.com/showAssembly.aspx?ukey_assembly=244714&ukey_make=865&ukey_model=20455&modelYear=1992&ukey_category=7866&ukey_driveLine=11320 Parts 8,7,6.
I accidentaly disconnected them and now as I put them back my oil pressure light has come on. Any ideas?
oktober 09 2016 13:20:50:
But still what bolt could be the one in the first picture?
Redigerat av Torbik den 09-10-2016 13:20
To change the oil in your engine you should have a drain plug on the bottom of the engine. You can watch this guide and you see where the drain plug is.Smile
Your other question about the oil pump i need to research what could have happendthinking
Torbik
In my car the original drain plug has been replaced with the one on the first picture .
Is it a allen/hexagon or a special head?
unsure ok they change the original plug.
The original looks like this and is a 25mm.
shop.klracing.se/bilder/artiklar/05145.jpg
oktober 09 2016 14:54:35:
Yes.
The oilpump problemthinking i dont really know what happend when you install the parts. I found some information on what could go wrong when reinstall the parts.
If you go to this link http://www.nuceng.ca/bill/volvo/Volvo...issing.pdf
And scroll down a few pages you have a few headlines to choose from. Go to Engine: Lubrication and there you have some information what maby got wrong. It starts with Oil Delivery Tube O-Ring Modification Is this guides they have lost the pictures Sad. But hopefully it could help you anyway.
Redigerat av Sladdaren den 09-10-2016 14:56
I recognize this plug from another car, if you are lucky, the shaft of a socket wrench set my work.
Good Luck.
Torbik
8mm hexagon fitted. All is well now.
Thanks
How did it go with that oilpump parts? thinking. Did you fix that to?
Torbik
Yes, disconnected it again and put back together.
The spring was badly insidr the first time probably.
This thread was solved
Thread locked
Redigerat av Sladdaren den 11-10-2016 13:06
D24tic Felsökning Volvo 240, 740 och Volvo 940 2 03-09-2019 10:31
Volvo 940 D24TIC valve cover gasket replacement Dina egna guider, Manualer, Instruktioner 7 28-10-2017 15:32
Volvo 945 D24TIC injektor - LÖST Felsökning Volvo 240, 740 och Volvo 940 5 28-09-2016 23:54
· Besökare: 31
100,977,860 unika besök
