Oktober 23 2026 01:20:13
Tråd ID: 1028
Det är 1 svar i den här tråden, och den har visats 49639 gånger.
Leaking sunroof on Volvo XC60
I got a question if there is any fix for leaking sunroof on XC60 and i found a how to fix guide below japp.
It is not uncommon that owners of Volvo XC60 cars are experiencing issues with water leaks from the
sunroof. The water can be found anywhere in the front area of the car’s interior, depending on how it was
parked during the rain. Water can travel down thru the A-pillars to the floor and/or it can drip via the roof
console down in the gear shifter/center console area.
Luckily, there is a fix for this (unknown to Volvo?). The water leak will stop if you shorten these pieces on
the front sunroof. However you need to remove the front sunroof to shorten them.
If you need a how to guide to fix this you can visit this link http://www.gunneby.se/xc60/Leaking%20...20XC60.pdf
· Besökare: 26
100,980,571 unika besök
