Oktober 23 2026 17:01:28
· Trådar, poster, Vol... 58599
· Nollställa service ... 35651
· Felkoder Volvo 940 h... 29380
· NY GUIDE Omklädsel ... 24677
· Felkoder Volvo 740 h... 22792
· Så här byter du va... 21677
· Besök Volvoswedens ... 20787
· Lösning på Felkod ... 20719
Tråd skapare: firstrebel
Tråd ID: 1474
P3 V70 door trim - Solved
firstrebel
I have a 2009 P3 V70 2.5T. The lower trim on the outside of the drivers door is loose and bangs when going over bumps. I looked at the Volvo diagram and it shows it is held by 6 clips. But it will not come off. Is there something else? I know the P2 had bolts from the inside of the door. I have taken the door card off but cannot see anything obvious.
Thanks
Bob
i.ibb.co/5K9DmZX/door-trim.jpg
i.ibb.co/cQThnbk/lower-door-trim.jpg
Redigerat av Sladdaren den 19-06-2024 12:20
www.volvoclub.org.uk
Hi
I am googling on this and find a picture on a door trim from rear left. This picture is from a 2008 year model. I see only clips that is held on this trim I post a link to it https://www.bildelsbasen.se/33-W18090...0907.html#
firstrebel
I found this photo of the back of the trim from a 2010 V70 and it shows only clips. Maybe they are very tight to get off. I will put a piece of double sided tape at the end of the trim and hope that will keep it secure.
i.ibb.co/vZG9Y32/lower-door-trim-rear.jpg
Redigerat av Sladdaren den 19-06-2024 12:19
Volvo V50 Power steering died - Solved Volvosweden in English 5 05-01-2026 10:09
1992 940 window problems -Solved Volvosweden in English 5 04-04-2017 21:36
945 cabin air filter? -SOLVED Felsökning Volvo 240, 740 och Volvo 940 11 13-12-2016 16:38
945 D24TIC crankcase -SOLVED Felsökning Volvo 240, 740 och Volvo 940 10 11-10-2016 12:53
· Besökare: 7
101,026,606 unika besök
